Virtual On Twin(Free)
kencinder
Alliston, Ontario, Canada
I've posted locally, but just incase someone not quite local is crazy enough...
Before you even ask, I WILL NOT ship this unless you arrange EVERYTHING yourself. I won't pallet, I won't wrap...come and get it, or get someone to come and get it and do that for you. It's FREE and if it doesn't get out of my garage by spring, it's getting GUTTED and DESTROYED.
The machines are in decent shape with some dings and scratches, but will need put back together and cleaned up, and I am not 100% certain they work.
There are 2 spare boardsets and 1 spare control panel, but 1 stick is broken on it.
1 monitor bezel but tinted glass for both sides are there.
Other extra parts are two extra audio amps and two smaller boards I can't recall what they are for.
Also a complete extra wiring harness from the PINK side I also have. I also have a complete wiring diagram for these.
With all the extra parts, you could almost build an entire other machine.
They do come apart into small enough sections that you could get them into a basement. Seats come off, top section comes off the base etc.
Most any 29" Nanao or Sanwa monitor should be a direct drop in on the frames. You will need Medium Res capable monitors.
Here's some pics, was very hard getting in at them. The bezel sitting on the pink machine is actually backwards, the other side is dark gray and faces out.
There's no t-molding missing on the pink right, the artwork plastic was removed to get it through a doorway, it covers that part.
Monitors are pictured but are NOT included!
