Virtua Fighter- why do I get ring out most of the time?
I have a Virtua Fighter that seems to work well after replacing the power supply.
It does have some audio static, but is understandable.
The game plays normal, but sometimes the character will slide by itself off the play area and then it will say "Ring Out."
If I am fighting and lots of times my character or the CPU will out of nowhere get off the playfield and get ring out, no matter how much you try to run the other way.
I notice there are some big PCBs in this thing. My new power supply might not have the same amps as the original, could that be an issue? Should I try reseating the ROM chips ??
Since I think it has a standard/medium res monitor, maybe I should just turn it into a 19 in 1.
