Video Of My RedTent Control Issue
SSilver2k2
Florida
I figured I would post a video of my issue with my RedTent. As you can see, the "slave" side of my RedTent is behaving erratically.
Also, while that is happening, sometimes the coin counter clicks by itself.
Any thoughts of why this is happening?
Are the joysticks wired normally closed or normally open. Should be normally open. Compare them to the working side.
I switched the control panels with a known working one. Same thing happens.
Make sure the EPMroms and PPU and CPU are secure tightly. If it's a daughterboard on that side those can be a bitch to seat right. My red tent was doing the same thing and it ended up being that the daughter card was not pressed down far enough. Worth a try.
J.J.
