Vertical sync problem after moving game
armyaviation
Enterprise, Alabama
I helped a buddy move a super hang on tonight about 5 minutes down the road. When we got it set up, the screen was scrolling vertically. We adjusted the vert hold but it was almost impossible to get it to line up correctly and when you powered off and then on it was screwed up again. Vertical sync problem? Could something have come loose, solder, wire
Find the video input wires - usually a group of 4 or 5 smaller gauge wires that plug into the circuit board of the monitor. Try tugging gently on the wires and see if you get any sync locking in while adjusting the sync knob. If you do, then your connector has cold solder joints.
