vertical snow on DK monitior help
djf
Monongahela, Pennsylvania
I have a arcade DK game that worked great then the game now boots up with a beep and snow on the screen No game noise screen toggles between snow and a line . just a little hum is all i hear Any help? is it the pc board? any help near Pittsburgh Pa? DJ [email protected]
Sounds like a board problem. Did you try to reseat the connectors? Where in the pittsburgh area are you located. I have a machine you can test your board in.
board test
thanks i live in monongahela , south of pitts I can come to you let me know if that works for you , not sure what you mean by reseat the connectors thanks DJ
Post a couple pictures of what the machine is doing? Can you coin the machine up and get any other sounds? I'm trying to determine if it is a CPU or Hold/Sync problem.
