Vertical Sagging
animesuperj
Mukwonago, Wisconsin
I bought a Gunbird at the last super auctions. The monitor works (I've played the game for about an hour with only this issue), but every now and then the picture, only about 2-3 inches in the middle, will sag down vertically (it's a vertically mounted monitor).
It almost looks like the hold is failing, but only in the middle section and about 2-3 inches wide. It will only sag down like that for a little bit, about 5-20 seconds; and then snap back into place. The rest of the image is fine while this happens, it's only that middle section that is effected and having the issue.
Is this just a cap kit fix, or something else I should look into? I don't know the monitor type offhand (I could get that later once I'm home), but I do know it's a 25 inch. I forgot to take a picture of this before it got too cold out in my garage, so the best I can do is try to explain it.
Thanks for any help with this.
That's what I figured, but just thought I'd see if something else is up that someone encountered before. I'll probably get it to once it warms up a bit around here. 20 degree and below weather sucks for working on these things.
