vertical movement on sanyo ez 20
talon93pete
superior, Wisconsin
Hi,
I have a sanyo ez 20 freshly recapped that I need to move the picture down about a quarter of an inch. I tried vr403 but did not see any change. Any ideas.
There is a shift jumper. Sometimes it's not actually present, but you can add it if it's not there and it will work:
thanks
Its in my cocktail, used to be popeye but was canned long b4 I got it. Now its a 60-1. Horribly dissapointed with the overdriven clipped sound on that board but my kids love it.
My gut feeling was that a jumper would be the answer, but my coworker that used to do arcade for a living could not confirm.
Thanks a bunch guys.
Yes, that is the answer. Frizz had a similar issue long ago (and even went to another forum for confirmation) and finally added a jumper and it worked...
Are you wiring the 60-in-1 directly up to the speaker, or to the audio amplifier in the Sanyo? The 60-in-1 is a Jamma board and has an audio amplifier onboard, and if you run the output through the amplifier on the Sanyo monitor as well, you'll have exactly that problem.
-Ian
No I'm not using the amp on the sanyo, just board generated sound.
I switched changed up my initial wire job from running a single speaker to running 2 in series. The extra resistance helped a lot but some games are still pretty cliped.
