Vertical Hold Problem - Sanyo - Cold Solder Joints ?
ScumBum
California
When DK stomps , the sound of the thump , and when I tap the cab , it causes the monitor to loose Vertical Sync . When the sound is off it doesn't loose sync . Seems like maybe cold solder joints somewhere , where would you look ? Any specific areas ?
I've replaced :
Vertical Hold pot on monitor and adjustment pot VR2 on the DK PCB
Capped the monitor and replaced tr402 and tr403 .
replaced D161
reflowed solder to IC401
I've desoldered VR403 and tested it while I shake it a bit and the reading is steady , so maybe the pot is good after all ? Should I just replace it anyways ?
I don't have any insight, but I'm curious. Does the monitor lose sync when you thump the cab with the sound off? I'm assuming yes.
Yep , you tap the cab and screen will jump or loose sync and start to slowly roll .
Verify that you have re-connected the ground wire to the monitor frame.
Thats the one by the flyback that connects to a screw ? If it is its connected .
I might have fixed the problem today . I reflowed solder to many components that have to do with Vertical and also VR403 .
I turned the game on and had to tweak the V-Hold knob a bit and after that it hasn't lost sync . I've cranked the sound to really test it and tapping the cab didn't affect the screen anymore .
So far so good , but it has stabilized before and then start up again out of no where , so the true test is after a couple days of playing .
Thanks for everybody's help !
