Yep, two different versions. Many original machines still have the 5 chip "yellow" set. The ones for download, and that chip burner guys will provide, are the three chip "Green" set.
Doesn't matter which one you use, as long as all the chips are from the same software version. I.E. can't mix and match. There is a slight change to a couple of factory settings in the 'green' set, but otherwise they play the same.
-Hans
