Vendolator VF125
If you have a key number from the lock, you can try the link posted above or Funtronics and see about a replacement key. Most square tops its just easier to drill the lock out.
Hmm... did you plug it in? How about starting with some pictures.. There isn't a whole lot to know about most of these machines..
really simple
There is nothing to these machines there is not alot of information out there because no one wants them. once you get into the machine its all self explanatory except for the coin mech but you will need to search for that information separately as these machines used several different coin mechs. Otherwise if its working simply turn on the thermostat and load it with soda.
