KenLayton
In Memoriam
Re: Vending Help.. Fawn Snack Machine.. Coin Acceptor
The original is a 220 uf @ 25 volts with axial leads.
Radio Shack # 272-1017 will work or a # 272-1018 if there's room for a physically bigger diameter capacitor on the board.
Remember you can go up in voltage rating. In this case the original is used as a power supply filter so you can even go up in uf to a 330 or 470 uf.
Yes all electrolytic capacitors are aluminum electrolytics.
