VEGAS 777 HELP
Tuck
Donor 2012-2013
Kamloops, B.C.
Is it possible there is a dip switch to turn a 777 board to standard rez or is it only medium
Yes. I think all games will do both 15 & 24k and the newest games like the pair of Gauntlets (with the newer video card) will also do 31k.
Some manuals for dedicated Vegas games don't fully list these options. Look at manuals for other Vegas games with similar hardware.
You're probably always fine running anything Vegas at 15k, but supposedly there can be a minor performance hit when running some games at 24k, like War: Final Assault, which is probably why they don't point out that DIP setting in that manual, for example.
I think it's dip bank 2-switch 2 to select between 15k & 24k on most of them.
It should be noted that certain games change the functions of the DIP switches. For example, Rush 2049 Special Edition (SE) removed the option to run at standard res. Also it seems some of the manuals out there are just straight up wrong as well.
