Vector Candidate?
WAGDAG
Oriskany Falls, New York
I came across this CRT (A48ABE10X) in an old TV that I picked up last fall. As soon as I cracked open the case, I noticed that this one was not typical. It is a 90 degree tube. Google search reveals CR-24 socket. It tested out amazingly well and has near zero burn, no scratches, and lots of emission life left.
Is it a candidate for a 6100? I've read a few posts stating that people have had success using a 90 degree tube with a CR-24 socket and that the biggest caveat was that the neck stuck out further. I would guess that the narrower deflection angle would have to affect the image, but I have no experience with that.
What's the deal with the zip tie holding that little ring assembly where the convergence rings normally sit? It seems glued in place. It's not a truly bonded design either because the deflection coil has a clamp like normal.
Anyway, If you think that this is something to keep aside for the vector lovers, I will. If it's just another tube with a less common socket, I may try and whip up an adapter to try out a K4900 or K4600. It has a nice long neck on it so the "new" yoke/rings should have plenty of room.
If it turns out to be junk, I will keep the neckboard for one of you that needs it to make a test adapter.
Thanks and good day...
Leaving aside the tube deflection angle, finding a 35 year old TV with a CR24 neck shouldn't be particularly exciting because you could get a much newer TV (with guns and phosphors in better condition) with a CR23 neck and simply change the socket on the K6100 neckboard.
That makes sense to me. I just figured that I would mention it here in case there was someone that was looking for this type to complete a project. Thanks for the input.
19" 6100's normally use 100 degree tubes (which are the less common type).
You might be able to turn it into a vector monitor by using one of Fred Konopaska's deflection board kits, and hand-rewinding the yoke yourself.
That does sound like an intriguing project. Thanks for the tip! I have enough irons in the fire at the moment so I will probably just put it back on the shelf for now.
