Hi guys, I bought this a while back as a way to continuously trigger a button for my shmups. I cannot remember if I tested it with a game but my oscilloscope tells me it works. I basically hooked up the input to ground simulating a button that is depressed constantly and I could change the frequency of the output signal flip flopping between 5v and ground. This would simulate a button press at different frequency. So you would hook up the IN to a button of your choice then wire the OUT back to the your pcb edge connector (essentially installing this in series with your button signal). The pot would then vary the frequency of the simulated depressed button.
In any case, I don't need it anymore so you can have it for $15 shipped in the US.
Thanks.
Paris
Thanks.
Paris
