V2000 R900 very very hot
jetusenet
Donor 4 years: 2011, 2013-2014, 2024
Staten Island, New York
Hi;
I am troubleshooting a V2000 HV cage and R900 is getting really hot. Everything seems to be running normally, great pic, HV diode is about 75 Deg. F but R900 goes up from room temp to about 250 Deg. F. in about 90 seconds, then I shut down the monitor, I don't want to kill anything........
My question is, does anyone know what the operating temp of this resistor should be??
Thanks in advance.
Jeff
Hi;
Thanks in advance.
Jeff
I found this info about that resistor here
http://pdf.textfiles.com/manuals/AR...XY (Version 1.1 dated 7 Feb 02) [English].pdf
Under the title . . .
THE HIGH VOLTAGE GENERATOR - OR - EHT SUPPLY ( . . .Page 7)
In particular this part
The input to the EHT supply is at pin eight of P900 where 40 volts AC is fed through a large
resistor, R900. Actually, this is a VERY important resistor because it limits, or regulates, the
current to the oscillator, keeping it from taking off on its own and increasing the high voltage to the
point where X-rays are emitted from the CRT, which is DEFINITELY NOT GOOD.
Also: this may help
http://ebookbrowse.com/gdoc.php?id=75606&url=5301048a87f5538447e75731389d04ea (Wells Gardner V2000 Manual/Schematics, Go to page 9, HV Hold Down, could be exactly what you need)
Dez;
Thanks for the info.
I have been monitoring the voltage during the temp. rise and it is constant.
The voltages are as follows:
~40vdc @ pin 8
~38vdc on one side of R900
~25vdc on the other side of R900
These voltages remain generally constant yet the temp of R900 steadily climbs. I let it go to about 325 deg. F. then shut it down. I am using my Fluke IR gun so maybe the temps are a bit off but I did the 'ol wet finger tip trick and it sizzled immediately, very very hot.
I shot the HV diode and it remains around 80 deg. F.
BTW, the cage has been rebuilt, new LESR caps, transistors and diodes......
Jeff
Dez;
~40vdc @ pin 8
Jeff
What's your HV sitting at (KV)
~40vdc @ pin 8
Jeff
Just did some calculations (Ohms law)
P = V x I
So . .
P= V²/R
The resistor is 15Watt (P) and it's value is 21Ω (R)
The Voltage across it, you said was 13VDC
So . .
P = 13 x 13 /21
P = 169/21
P= 8 Watts
Since the Wattage is 15W, nothing will happen.
If the voltage across R900 doubles to 26V, you have a problem
Did you ever find a solution to this issue? My R900 gets VERY hot as well then after a few minutes starts causing the screen to bloom.
