Okay. Here is the list.
THIS IS THE LIST FROM ----
www.junknet.net/donor-tvs ----
19" Daewoo DTQ20J4FC A48JLL40X
Drop-in Replacement for K7000, yoke works
Verify TV model # (number has 20 in it but has 19" tube)
19" Emerson TV/VCR/DVD Combo EWC19T2 A48LRH93X
Horiz- 3.0ohms
Vert- 12.8ohms
Possibly CR-31 (thin neck) - Need verification. Manu June 2002
19" Hitachi CT1933 A48AAJOOX
Horiz- 3.4ohms
Vert- 56.2ohms
Reported this worked as a drop-in replacement for G07!(yoke conn has to be swapped)
19" MGA/ Mitsubishi CS-1902U 19VJTP22
Horiz-2.2ohm
Vert- 52.5ohm
THIS IS A DIRECT NUMBER-FOR-NUMBER DROP IN FOR G07!
19" Montgomery Ward PL1933Y1 A48ACB02X
Horiz- 3ohms
Vert- 9ohms
Zenith tube, Manufactured 1989.
19" Orion 1929 A48AGY13X77
Horiz- 2.5ohms
Vert- 14.4ohms
Orion tube, CR23 (fat neck)
19" Orion TV1925A A48ACB32X
Horiz-3.5ohm
Vert - 9.5ohm
All black case. Built Feb 1996. TV has galvanized tube brackets
which can be reused for whatever.
19" Philips PR1910B01 A48JLL90X
Horiz-3.2ohm
Vert-15.2ohm
8 pin
19" Panasonic CT-9010 19VJTP22
Horiz-2.2ohm
Vert- 99.ohm
Classic 1980 TV with wood grain case and knobs!
Exact tube number for G07, however the vertical is twice what it should be.
19" Panasonic CTF-1911 510ABY22
Horiz- ohm
Vert- ohm
Tube is CR-23. Waiting on yoke readings.
19" Quasar TP1921FE-3 A48AFN00X
Horiz-5.1ohm
Vert- 16.1ohm
CR-31 (thin neck)
19" RCA CTC15xxx (XL-100)A48AAB1202X
Horiz-3.8ohm
Vert - 11.7ohm
Newer black XL-100 model with rounded speaker mouldings
19" RCA F19240GY A48AAB13X02
Horiz-5.6ohm
Vert- 13.2ohm
CR-23(Fat neck/standard)
19" RCA F19421W A48AGY13X55 CR-23 tube
19" Sanyo 91C530 19VMFP22
Horiz- 2.2ohms
Vert- 52.4ohms
Good for K4900, manu 1983
19" Sharp Linytron 19NP58 A48ABK04X
Horiz- 3.6ohms
Vert- 16ohms
Tube is CR-31, which is a thin-neck tube. Good for K7000 swap, may work directly. Manufactured 1988.
19" Samsung CXC1912 A48KZL90X
Horiz- 3ohms
Vert- 13ohms
Toshiba tube, CR31 (thin neck), Manufactured 1994.
19" Toshiba CF19G22 A48JLL90X
Horiz-4.6ohm
Vert-9.3ohm
8 pin
19" Westinghouse WT-1942 A48LGS30X18
Horiz- 3ohms
Vert- 13ohms
Orion tube, CR31 (think neck), Manufactured Sept 1998.
19" Zenith Z19A02G A48ACB32X
Horiz-3.4ohm
Vert- 8.4ohm
19" Zenith SC3931W A48ACB02X
Horiz-3.2ohm
Vert- 9ohm
Prob could be used as drop in replacement for K4600
19" Zenith SLS1937S A48ACB02X
Horiz-2.5ohm
Vert-8.9ohm
Drop-in Replacement for K4600
19" Zenith (S)D1914W A48ACB02X Man Oct 1987
19" Zenith SD1915W A48ACB02X
Horiz-4.4ohm
Vert - 9.7ohm
Chassis SD1915W
Tube is drop-in for Wells K4603 Also seen Vert=8.5, Horiz=3.2
