Using JROK converter with OLD tv
willymotts
New York
If I buy a JROK board to use a tv in my Ridge Racer, can I hook it to a very old tv that only has the 2-screw antenna and the coax cable inputs? Thanks.
You need something to adapt the signal to coaxial for the TV. the easiest way would be to get an old VCR with RCA input, run the RCA output of the JROK adapter to the input of the VCR, then run the coaxial output of the VCR to the TV. This would also allow you to tape your games for later playback....
