using happ guns on carnevil
mudhens1
chillicothe, Ohio
is there a way to do this?
should i combine the trigger and reload wires together so it reloads everytime it shoots? the happ gun that's on there now registers on screen, but all the shots are just barely visible on the far left side of the screen...i recalibrated a few times, but it didn't help
Pretty sure it auto reloads when you shoot outside the screen so you
don't need to hook up the reload wire.
Carnevils always have tracking problems. The monitor needs to be bright and
sharp and you need to verify that sync cable is properly spliced into the monitor
section of the harness.
JD
