using computer monitor?
Yea need to change the dip switch on the 60 in 1 board. One of the local guys near me sells multi cades and I know he uses deboxed computer crts in cabinets that had a lot of burn in on them. Generally they work fine.
thanks for the info knew it had to be something simple.looks great now just have to build a bracket to hold it. any ideas on that? thanks again-james
Can you post some pictures of what you are working with?
I've seen people just put a shelf in the game cabinet and sit the monitor on it. Overs take it apart and mount it the same way the original was.
You trying to use a crt monitor or an lcd? If it is a crt you should be able to pull it apart and either mount it to those holes on the monitor bracket it drill new ones. If it is an lcd maybe a versa mount on a board.
