Using an external switch as a dip switch...
modessitt
Austin, Texas
I have a test board that can output standard or medium resolution for monitor bench testing. Only one dip switch needs to be changed to change resolution. I have this board mounted on a wall, and would like to have an external switch on my bench that I can flip to change the resolution easily from my chair, rather than going over and flipping the little dip switch with a little screwdriver.
I assume that if I leave the normal dip switch off, I can connect wires to both sides that go to my external switch. But I'm wondering whether I have to worry about wire resistance (about 18" each way) or switch resistance when doing so...
I wouldn't think so. If it does, you've got two options. 1) Put a larger gauge wire in to drop resistance and see if it helps. 2) Put a cheap transistor like a 2222 in place of the dip and drive the transistor with your switch and +5V.
Personally, I'd try extending it with some 20ga and see what happens, if that fails I'd drop in a transistor and skip the larger gauge entirely. Actually, as I write this, I'm thinking I'd flip the board over and throw a transistor in parallel with the switch. If you decide to revert later, just clip the transistor out.
That'd be no problem at all. There's almost no current going through the switch, so the little amount of resistance has almost no effect. There's probably a 10k pullup or something on the board, so as long as you're not anywhere near several k resistance, you'll be fine.
DogP
It will work fine, done it before for a pause switch on a pacman. Had a toggle that would switch dip 8 at the same time cut out the speaker.
