Can you just use the DOS command...
Copy/b file1.bin+file2.bin target.bin
Where file1.bin and file2.bin are just copies of the same file?
I'm working on a Battlezone and 5 out of 8 ROMs were bad. I don't have many 2716 EPROMs but I have loads of 2732s.
From everything I've read online I think it should work no problem, but I just want to make sure. I get paranoid sometimes about simple things.
Thanks in advance,
Jeff
[edit]
Forget it... found 4 or 5 old threads about it. Should have used the search function a little sooner...
Thanks in advance,
Jeff
[edit]
