joeyoravec
I'm fixing a Taito Space Invaders TVN boardset. This post shares what I've learned about modifying the Taito and Midway boardsets to use other kinds of EPROMs. I don't own a Midway boardset so I've only verified the info for Taito.
My board came with 2708 EPROMs which really stinks. 2708s are ancient and difficult to buy. 2708s require three voltages (+5, -5, +12v) so my EPROM programmer cannot read or write them. Fortunately 2708, 2716, and 2732 eproms have a similar pinout (link). By modifying pin 19, and pin 21 it's possible to substitute a more common chip like 2716 or 2732.
Both Taito and Midway board have jumpers to configure those lines. Midway published a table (link, final page) that offers settings for 18 outdated chips, but not 2716 or 2732. Taito published nothing that I could find. Taito scans on xmission are low-resolution and unreadable so use this instead (link).
Here's an explanation of the two boardsets:
You'll notice some useful settings are missing. S3 doesn't offer A10. S2 doesn't offer +5v or A11. The jumper pad is used to get a signal into the chip.... but you might have to find the signals nearby and run a longer wire. Now you have a few options:
I'll probably install the original number of 2732's, since it's so easy to get ground to those pads. But any of those work. I'm not sure if Midway has a jumper for ROM select bit 3, so you might be limited there.
I've attached a photo of my Taito TVN board with the signals. Unfortunately KLOV forum shrank the image and it's extremely difficult to read, so probe it yourself with a DMM. Here's a guide that shows you what to do on the Midway boardsets (link).
Code:
Midway Taito Purpose {settings}
S1 S1 ROM pin 22 {5v, A9, GND}
S2 S2 ROM pin 21 {-5v, A10, GND}
S3 S3 ROM pin 19 {12v, 5v}
S5 S4 ROM pin 18 {5v, GND}
S6a S5 ROM select bit 0 {A9, A10, A11}
S6b S6 ROM select bit 1 {A10, A11, A12}
S6c S7 ROM select bit 2 {A11, A12, A13}
S8 ROM select bit 3 {A12, A14, GND}
- Use 2716 (original number): S3 Pin19=GND. S2 Pin21=+5v. Program 1k images to the bottom-half of each chip.
- Use 2716 (fewer): S3 Pin19=A10. S2 Pin21=+5v. Change ROM select to {A11, A12, A13, GND} so each ROM socket has 2k. Combine images, program 2k to each chip, and install in the correct sockets.
- Use 2732 (original number): S3 Pin19=GND. S2 Pin21=GND. Program 1k images to the bottom-quarter of each chip.
- Use 2732 (fewer): S3 Pin19=A10. S2 Pin21=A11. Change ROM select to {A12, A13, GND, GND} so each ROM socket has 4k. Combine images, program 4k to each chip, and install in the correct sockets.
