Username Changes
Status
Not open for further replies.
Just an FYI, the tool I use to make the changes across all of the databases has not been modified to work with the new Xenforo forum database yet. The change username feature will never be a guaranteed thing and the priority of the script modification is low on the list of things to update.
I dunno if this is a dead topic, and if so I'm sorry Tombo. But... here's a request:
indecks -> HornheaDD (or HornheadDD - re: edit below)
Thanks.
edit: I actually use this name on a different Xenforo forum, so now that I think of it - it might cause a problem. If so, maybe adding a lower case d will help. So 3 D's all together :D
I would like to kindly request a username change to AtariGamer78. If that is not available, please try PMUR6189. Thank you for your help.
FrizzleFried > YourMomSaysHi
Just checking in on this. I do know I am breaking a rule by doing so, but come on, it's been going on three years. The username is under 16 characters (well, between 3 and 16). I broke no other rule. I am pretty sure that there isn't anyone named YourMomSaysHi in any of the Databases. Up until today, may I ask which 'rule' was broken so-as that my request be ignored?
...askin' for a friend.
( For those who can't read ) --- I am also guilty of this.. i would love to remove my fcc callsign as my username, but doesn't look like it will happen.
Username change request
tubedood ----> Tubedood
Forgot the cap when I created it.
Who knows when these Username change requests will be done. I've been waiting for mine to be changed for 2 years now. Like yours, it's a matter of capitalizing letters. Nothing complicated.
For the challenged:
I am starting a new thread since most seem to miss the requirements.
Only ask once
Name changes are done in batches - it is not instant
Special characters will not work
Spaces will not work
Underscores will not work
New Username must be between 3 and 16 characters
Bumping the thread will null your request
Do not PM us about your name change request or status (unless you are in WITSEC) Doing so will null and void your request.
Note A: If you cannot follow these simple guidelines, your request will be ignored.
Note B: A name can only be changed when it doesnt exist in ANY of the WM databases. In a reply here, you will be informed of this. The Xenforo database is one of several WM databases. There is currently no way for a forum user to search the other DB's.
General reminder
But you forgot the most important part:
Status
