Username changes - old requests
Status
Not open for further replies.
Change user name
Hello I would like to change me user name pm sending.
I'm an Admin at 2 other places, one running the same board soft as here...takes all of 10 seconds to change a username.
BTW. So does not take 10 seconds here. The forum base is vbulletin but due to the integration with the main site it is a more involved process and involves manually tweaking multiple tables on multiple databases on more than 1 server. Plus we log the name change to the user's profile for all to see permanently, with few exceptions (if there is a particular need, we can make an exception). Include the time to interact with the user, it's probably closer to 10 minutes each, just slightly less with several at a time.
It's getting easy than it used to be though. Due to a glitch in the vBulletin admin interface that normally isn't an issue but made it incompatible with our modifications, we couldn't edit anyone using the back-end tool here if they had a VAPS link. I'm about done with a work-around which should make things easier.
At some point I'll probably just write a script to make it an easier process, but it hasn't happened yet.
If people want a username change, it's a very good day to ask (or re-ask). New requests will get the attention first as I don't have to go hunting for old PMs.
Status
Similar threads
