Steelhorse
Here is a full playfield shot. You can't really tell which inserts were done. I did the left lower side in clear concave leds and the right lower side in frosted cointaker's leds.
Right side ( Cointaker frosted )
Left Side ( concave )
Stop Light done in clear concave LEDs
Super Bright Green under the plastics... I don't really like this look, it changes all the white lettering to green. I will be changing it when i fully shop the pin out. I think the frosted look good.
Get rid of the cool white down by the flippers, replace them with frosted red as the art in the area is red. Take out the cool white from the slings and put the #47's back in. Take the green out of the target area and put the green ones at the hide out holes, which will highlight each hideout lock spot or toss'em. Then it would be killer, IMO and it is what I have done to my HS, just leave the G.I alone. Hey have you done your backglass yet? You might as well so it all flows together. i just had my PF LED without doing the backglass for a longtime and you can see a huge difference in brightness so balance the machine up if ya have not already. Cheers fellow HS owner.
