souzilla
I am going to update the 4-in-1 hack located at http://arcade.souzaonline.com
I am adding freeplay/coin up with attract and a high score save
If anyone wants to play around with the HSS you can get it from here (pac only for now)
Once i freeze the code for this I will port it to ms Pac
You can download it from here
http://www.souzaonline.com/temp/mame_pac_hss.zip
This is a self contained shrunken version of mame.
Just uncompress and run the following
Pacman with HSS: run_pacman_hss.bat
Pacman Original: run_pacman_orig.bat
Issues to fix
1. FREEPLAY/HSS: we need to be able to start or insert coins when attract (HSS screen)
Issues to fix
