Updated parts wanted: Frogger PCB, coin door, and vertical monitor frame
jimbodeanny
I'm still hunting for a coin door (or just some replacement parts) for my Frogger.
Information about the coin door I'm looking for is here: http://forums.arcade-museum.com/showthread.php?t=132805
I'm also looking for an original konami-style 36-pin Frogger PCB. The one I have is a 36pin style bootleg board that plays great. The only difference is that at the title screen, the frogs spell "Frog" instead of "Frogger." I need an original board because I want to install the high score kit and it doesn't work on this PCB.
Lastly, I'm looking for a vertical monitor frame. I just bought a new monitor and need a vertical frame so I can mount it.
Shoot me a PM and/or reply to the thread if you've got any of this stuff. Also, please list what you're asking.
Thanks!
-Jim
I have a vert frame from a MsPac upright, if that works for you, let me know
Doesn't Ms Pac use a horizontal mount monitor turned on it's side like Pac man dose?
I know My Pac man dose. My Frogger has a true vertical monitor mount.
Pictures below.
yeah the frame I have doesnt look like that, I guess yours is mounted on a flat board? the frame I have bolts to cabinet sides (You would need to make that bracket) but is square tubing that bolts to frame? and holds it all in place?
Anyway its free if you want it, just pay shipping, I guess will all unbolt
No look at the 2 monitors, the picture on the left and the one on the right.
Both monitors are K4600 monitors and both are sitting flat on the floor but one the tube is horizontal and the other is mounted Vertical. Everything on these 2 monitors are the same but the frame.
Yes in Pac man they added 2 metal bars to mount the monitor on the side but If you did this in a Frogger cabinet the monitor frame would stick out the back and you cant put the back door on. That's why you need the true vertical mount frame.
$49.99 plus $18.00 shipping for a incomplete coin door is crazy but you could make an offer but then you still have to find parts. :eek:
http://cgi.ebay.com/RARE-GREMLIN-CO...tem&pt=LH_DefaultDomain_0&hash=item414f0e61b1
That's not the same size as the door I have. Mine is a little longer, like the door used in Space War. Like this one: http://www.tokensonly.com/images/collection/vectorbeam/space_war/images/space_war_186.jpg
My door is simply missing one of the coin return "catchers."
Found a seller for the vertical frame.
Still looking for a Frogger PCB (36pin konami style) and the coin door/parts.
