Untested Atari ARI and ARII boards $15@
I have a VERY LARGE lot of untested ARI and ARII boards that I will never get around to testing. Some will need R29 or R30 replaced, others might need capacitors replaced or might be missing a transistor. Many will have no signs of issues at all. Most of these came from operators who pulled them from games where they sat on a shelf for the last 20 years until I acquired them. I have a large quantity of ARII-1 and ARII-2 and a smattering of the other versions. The ARII-3 and ARII-6 are $25 each however due to their scarcity. I don't think I have an ARII-5 and cannot say if I have ever seen one. However, if you need one be sure to ask as I haven't inventoried all of these yet. If you don't know which version board you need, you can check your manual or Alex Yeckly's site. ( http://elektronforge.com/AudioRegs.htm ) I know for a fact that many Missile Commands do not like anything but an ARII-3. The ARII-2 is a great universal replacement for most other games. If you order one or two, I will probably ship in a priority mail box. Anything more than that will ship via UPS Ground.
I have approximately 20-25 ARI boards available in different configurations. I have a couple of the Lunar Lander style and about an equal amount of the Asteroids and Asteroids Deluxe styles. Again, if you need a specific version of board, be sure to be specific. ARI-1 are for Asteroids and ARI-3 are for Asteroids deluxe. The Lunar lander style is for the pinout with the 4 pins in a row on one of the connectors. (J8) I will have to reconfirm this information when I dig them out. All the ARI are $20 each.
Shipping is obviously extra. Prices above include an offset for PayPal fees so you can pay directly after I get you a quote for everything. Just send your want list to me via PM. I will pull boards that are fully populated or maybe have a burned resistor (as determined with a quick scan) and as the stack dwindles, I will sell the ones missing a cap or two. If it is vital you have only fully populated boards, be sure to let me know in your request. I won't sell a board missing lots of components. If however you are in the rebuilding business, I have about 10 of various styles I can sell for $10 each.
Local pickup is free and you get the option of digging thru the boxes. Currently have about 120 of these boards to sell. I'm willing to estimate that about 40% of them will work just fine. However, if you are buying these to replace yours with the burned resistor, you will just have the same thing happen to this ARII board unless you fix the edge connector on your main harness to the circuit board.
If you have questions, please post them here so that others might benefit from the answer. Boards are for the most part clean and presentable. Remember, these are truly untested. If you must have a tested working one, I recommend you look elsewhere. I am too busy now to test/fix these.
