portkey
Okay. So I figured it out. Here is what the config.txt file looks like and it works to connect directly to an LCD via a HDMI to VGA converter.
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=30
#overscan_right=30
#overscan_top=10
#overscan_bottom=30
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=16
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
#dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
#dtoverlay=vc4-fkms-v3d
#max_framebuffers=2
[all]
#dtoverlay=pi3-disable-bt
#dtoverlay=disable-bt
#dtoverlay=vga565-3
#dpi_output_format=421907
#enable_dpi_lcd=1
#display_default_lcd=1
#dpi_group=2
#dpi_mode=87
#dpi_timings=320 1 16 30 34 240 0 2 30 22 0 0 0 60 0 6400000 1
#dtoverlay=pwm-2chan,pin=18,func=2,pin2=19,func2=2
#dtparam=audio=on
#dtparam=i2c_arm=off
#dtparam=i2s=off
#dtparam=spi=off
#hdmi_safe=1
#disable_overscan=1
#overscan_left=30
#overscan_right=30
#overscan_top=10
#overscan_bottom=30
# overscan.
hdmi_group=2
hdmi_mode=16
hdmi_drive=2
# no display
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
#dtparam=audio=on
[pi4]
#max_framebuffers=2
[all]
#dtoverlay=vga565-3
#enable_dpi_lcd=1
#dpi_group=2
#dpi_mode=87
#dtparam=audio=on
#dtparam=i2s=off
#dtparam=spi=off
