Dk1983
HDMI FORCE OUTPUT RASPBERRY PI
@portkey did a great job figuring out how to allow use of the raspberry pi hdmi port, in case your monitor is dead and you have a spare lcd you'd like to hook use. I was unclear of the process, so once I figured it out I decided to post this for others to use.
It's an easy change.
You need to edit your text file on your Pi SD card.
Which is as easy as copying his file text and pasting in the config.txt folder on your SD card. I've pasted the correct file to copy/paste below.
I would suggest copying your original file and pasting elsewhere in case you want to go back to not using the hdmi port on the Pi
Here is a link on 3 easy methods to edit your Pi depending on the computer you own.
COPY AND PASTE THE BELOW TEXT TO CONFIG.TXT FOLDER
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=30
#overscan_right=30
#overscan_top=10
#overscan_bottom=30
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=16
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
dtoverlay=pi3-disable-bt
dtoverlay=disable-bt
dtoverlay=vga565-3
framebuffer_priority=2
dpi_output_format=421907
enable_dpi_lcd=1
display_default_lcd=1
dpi_group=2
dpi_mode=87
dpi_timings=320 1 16 30 34 240 0 2 30 22 0 0 0 60 06400000 1
dtoverlay=pwm-2chan,pin=18,func=2,pin2=19,func2=2
dtparam=audio=on
dtparam=i2c_arm=off
dtparam=i2s=off
dtparam=spi=off
#hdmi_safe=1
#disable_overscan=1
#overscan_left=30
#overscan_right=30
#overscan_top=10
#overscan_bottom=30
# overscan.
hdmi_group=2
hdmi_mode=16
hdmi_drive=2
# no display
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
[pi4]
max_framebuffers=2
[all]
dtoverlay=vga565-3
enable_dpi_lcd=1
dpi_group=2
dpi_mode=87
dtparam=audio=on
dtparam=i2c_arm=off
dtparam=i2s=off
dtparam=spi=off
