MMAO - Game: Universal Magical Spot Cabinet
Arcade22
Donor 3 years: 2012-2014
Georgia
I've got a Magical Spot cabinet from Universal available. It's a pretty funky cabinet (see example pics below & I'll get pics to those interested) got the coin doors, coin box, monitor bezel, "interior bezel" above the monitor (if that's what you call it) and missing the other parts because it was converted to a Mr. Do at some point.
If you're interested as-is, MMAO via PM. Located in Atlanta, GA.
I now have a Dropbox folder set up so those that are interested can see high res pics. PM me with your email and I'll share the folder with you.
Thanks!
MAKE ME AN OFFER (mmao)
Low Res Pics #1
Low Res Pics #2
Low Res Pics #3
Low Res Pics #4
Low Res Pics #5
I'm trying to find time to get back to all of the PMs I've received... for all that are interested, I'd like to keep the cabinet intact if possible, but I'm not dead set on that since I won't be of much help if it needs to be shipped.
The monitor is original, It's actually a factory conversion TV with a wood frame and the monitor shroud around the tube is the front of the TV case. It works and has no burn but I think it is spoken for at the moment. I'll update those interested if that changes.
Monitor Type? = I'm not sure which model it is, but it's not a WG, Electrohome, Sanyo, etc. It looks to be what came with the cabinet when it was built in Taiwan, wood frame and the numbers "2431381A" clearly visible on the flyback.
The cabinet areas and other artwork that had "nudity" were altered at some point here in the US, most certainly because it was going into an arcade where younger people would be. The backdrop artwork is held in by little nails and has a cracked area in the lower rignt. I've taken a close look at that artwork piece and it appears to have been scraped off from the back side and hit with some flat black spray paint to cover the resulting "clear" spot (see pics). The two women on the front appear to have been taped off over the breast area and painted over. I'm sure this could be removed to show the original artwork underneath. I may attempt this soon. The control panel needs a light polishing of the stainless and there's one cigarette burn on the 1 player button, but otherwise solid.
I haven't attempted to clean any of the cabinet at all. There is no game board, "Magical Spot" marquee or power supply.
Again, please see the pics and let me know via PM if you want the link to the Dropbox folder with high res photos, if you have an offer, etc.
Thanks!
OK, another update. Per request, I did a quick 5 minute cleaning of the front of the cabinet and it looks GREAT! This is with minimal effort and I'm sure the paint over the ladies' chests would come right off with the proper remover. The coin door would need to have some denting bent back and resprayed, but like I said, after a quick once over, it looks really good. I have a high res version of this pic I can send to anyone interested.
Thanks!
A few more....
...and still a few more.
**BUMP**
...and to let you know that the cabinet is going to the part-out pile. It will be stripped and parts sold off. I'm done messing with it. Let me know if interested. I'll be stripping everything, nuts, bolts, etc.
