Universal 19 and 25 inch Wei-Ya Chassis, what are they compatible with?
DreamTR
SMYRNA, Tennessee
I have read the 19s are compatible with G07 monitors. Any others?
For the 25s we tried on Hantarex and that did not work...just trying to see who knows exactly what these are all compatible with
I just bought one for my polo... there is a youtube video that a klover posted showing it working. I havent installed yet but will get to it this weekend.
I would like to know the list as well... is it confirmed the 19s will work with G07?
It all depends upon the Wei-ya chassis model number. You have to know some specs of the yoke and tube you're going to use and select the appropriate universal chassis:
Low impedance yoke, 10 pin (29mm diameter) tube neck, requires isolation transformer. Model 1220-H for 19" tubes.
Low impedance yoke, 8 pin (22.5 mm dia) tube neck, requires isolation transformer. Model 1220-S for 19" tubes
High impedance yoke, 10 pin (29mm dia) tube neck, requires isolation transformer. Model 820-H for 19" tubes. Works well to convert an Atari Disco standard resolution monitor.
High impedance yoke, 8 pin (22.5mm dia) tube neck, requires isolation transformer. Model 820-S for 19" tubes.
Low impedance yoke, 10 pin (29mm dia) tube neck, does not need an isolation transformer. Model 2620-H for 19" tubes. Model 2420-H has a contrast control.
Low impedance yoke, 8 pin (22.5mm dia) tube neck, does not need an isolation transformer. Model 2620-S for 19" tubes. Model 2420-S has a contrast control.
High impedance yoke, 10 pin (29mm dia) tube neck, does not need an isolation transformer. Model 2820-H for 19" tubes.
High impedance yoke, 8 pin (22.5mm dia) tube neck, does not need an isolation transformer. Model 2820-S for 19" tubes.
Add a "-R" suffix to any of the above model numbers if you want a model supplied with a remote adjustment board. They normally have all adjustments on the monitor main board.
Remember, the yoke wiring and connector pinout of the Electrohome monitors is different than other monitors. The yoke wiring must be modified first to conform to the new universal monitor chassis or else both the yoke and new chassis will be destroyed immediately upon power up.
