United Bonus Baseball
sguenther
Lincoln, Nebraska
I just got my 1962 bonus baseball up and working. It's doing pretty well with only a few quirks. At times it gives me a triple when I hit a home run or a double when I get a triple, but everything else works fine. I'm looking for a quarter or dime mech. Not sure if they came with quarter mechs, but I have one hole in the front part of the cab that is covered with a piece of metal and it looks ugly, so I want to replace it. I also wouldn't mind finding a plexiglass sheet back where the home run hole is. Anybody have a parts machine out there?
I think that game has one relay for each base scored and they drop out in sequence as they make it to the base, so if you look at the mech baord and make a triple you should see the 3 relays used. It's likely that one of them has a bad contact.
I'll check out those relays. It occasionally happens when I get a triple and only moves the runner to second. That narrows it to probably the second base relay.
