Underside of an MCR power chassis
JC Arcade
New Jersey
Anyone have a pic of the underside of an MCR power chassis? I'm deconverting a Tapper that was converted to a Double Play Baseball, and when I went to replace the two big caps, the old caps had burn marks on them and what looks like resistors attached to each one. I'll take a pic tomorrow if no one has a pic to share.
Also, anyone happen to know what size screws to use for the +/- terminals on the new 100k and 55k caps?
I've taken apart and restored several of these power bricks and the resistors you see attached to the caps are supposed to be there.
Thanks Chris. I have a power brick pic from your Journey resto printed out as a reference for the top side. :)
The resistors across the caps are to discharge them when the power is turned off. The caps are very large value devices and could otherwise hold a charge for quite a long time possibly causing game booting issues (if switched off then on in a short time frame) and also for safety - so you are 'less likely' to get belted when snooping around in there..…
Vic, Homepin - thanks so much for the pics and the info on the resistors.
Are those cap posts that the wires hook on and the nut goes onto removable? I tried getting one off the old cap and it wouldn't budge.
Yes they are removeable. I had to wd-40 them and let it sit for an hour or so then maybe you can use an allen wrench to get them off. As I remember though, I used a nut driver with an hex bit to get them out. The screws themselves I believe are 1/8 inch diameter. You could just rig something with a new bolt and nut(s) to tighten the connections down. Obviously the screw lugs that came with the new caps aren't long enough to hold all those darn wire connectors.
