Umk3 sound problem
xaryC
West-Vlaanderen, Belgium
Hi,
Some days ago I bought a umk3 pcb from ebay listed as 100% working but no sound.
For 10 bucks I tought I'd give it a go...
Just installed the game in my mk3 cab and there is sound, but it seems like it's not amplified.
When I adjust the volume in the menu, the volume goes up and down, but the sound is very flat and not as loud as my mk3 pcb.
Any ideas what I could check?
Voltages should be right because my mk3 pcb works perfect (?)
Problem solved
If anyone should encounter the same problem, try changing the tl084cn op-amp ic, it worked for me :D
I Also changed the 2200uF cap and the tda7240 amp, but the new tl084cn did the trick!
My umk3 pcb is fully operational again, and this for 10 bucks plus a few bucks for the parts :D
I can finally sleep again ;)
Good work on the fix. Thanks for updating this thread so we have it in the archives.
