UMK3 jamma harness
jmookie
Arizona
Hi all,
Does anyone know what type of Jamma harness a UMK3 pcb uses? Is it a standard Jamma harness?
Yes it should be standard
Ok, I would also need a UMK3 extra buttons auxiliary kick harness ?
It is standard but you what to make sure the -5v is hooked up in the harness. Some harnesses don't have it and umk3 requires it for sound. Otherwise you will hear a load screeching sound. And the kick harness for the kick/run buttons
