Ultracade question
donnyjj2005
Ohio
Monitor tells me "No signal" and its beeping...any help would be great
are you running it on VGA or CGA, have the dongle for the monitor resolution in place? or not? how many beeps? as could be memory
No sure what its running, these were put out by Shaffer Distrub. It has a black comp mounted in the bottom of the cabinat, with a 27 inch monitor. The beeping is steady
How many beeps?
is it s a Beep Beep Beep Beep Pause Beep Beep Beep Beep Pause Beep Beep Beep beep...
or is it a
Faster...
Beep Beep Beep Beep Beep Beep Beep Beep Pause Beep Beep Beep Beep Beep Beep Beep Beep Pause Beep Beep Beep Beep Beep Beep Beep Beep Pause Beep Beep Beep Beep Beep Beep Beep Beep Pause Beep Beep Beep Beep Beep Beep Beep Beep Pause
First Scenario: Ram Issue
Second Scenario: Video Card Issue
