Ultimate Mortal Kombat Move List Project - Give your input!
ebo0763
Donor 2012, 2016
NB, Canada
This is a project I'm starting with you guys in order to complete and correct a move list to install around the bezel of the cab, preferably if you have a 6-in-1 with MK1, MK2, MK3 and UMK3 or a MAME cabinet.
The moves I used here may not be accurate since I've seen different moves on different sites. One part that I'm least confident is the finishers for example, often then distance is not clear or debatable. So I need your help to correct it. If you or a friend of yours is knowledgeable in MK, I would ask you to participate in this project.
I want to leave this project going for a while so people can add their bits of knowledge and by the end we should have a very accurate move list available to all. Once we consider it done, I'll edit it as needed and will post a high resolution version for all of us. And if you don't have an MK cab, I could adjust it for you.
All your corrections should be clear and look something like this:
MK game:
Character Name:
Original move as listed:
Correction:
Comment:
An example would be:
MK2
Baraka
B, B, B, LK
It should be: B, B, B, LP
I love your mom... she's so fine ;) (or any other relevant bits)
P.S.: I'm also working on a way to make it momentary backlight by holding Start+Run. I'm thinking of sticking LEDs on the side of a white 1/8" lexan at the back of the moves list and replacing the 1/4" glass for a 1/8" to compensate. The challenge is to find tiny LEDs that are not surface mount...
WARNING! Please do not use this file to print since; it might be incomplete or contain errors, the proportions are not yet perfectly adjusted and it's not the full resolution version.
http://i.imgur.com/p08HZ5i.jpg
I did notice the fatalities in order to Babality friendship etc
Perhaps you can do yellow , light blue, etc to differ
Maybe be easier to decipher at a quick glance
Good point. I'll try it. Thanks.
When I did my MK2 move poster I used the colored blocks and font. I thought that made it easy enough to decipher at a quick glance.
One thing I will add is the Rain is not playable in the arcade version of UMK3 so he needs to be removed from the bezel, unless you want to keep him in there for the Mame/home console people. Noob Saibot has NO fatalities and NO special moves for the arcade version of UMK3, so his card needs to be re-done to reflect so.
You can use this site to compare all your moves to as this site is all correct...
http://www.mksecrets.net/umk3/eng/umk3-specialmoves.php
Noted. I thought I would keep because one, it's an hommage to him and second and most importantly, everything is symetrical so removing would screw it up.
Yeah I could just check individual moves but... but I've put many hours in this already so if someone wants to do a part that would help me big time. I guess mksecrets should be a good source...
If anyone is interested in this list, please contribute by double checking a coupe of characters and post what you did.
If you rely only on myself to complete this, there will be errors. Please correct me so we can have a perfect move list.
Thanks.
i will be testing out your move list that you have soon. just need to hook up the games this week. ill start with mk2 then umk3 and will update if something dose not work.
Very good, thanks. Do you plan to use the arcade version? It would be prefered. Especially with the fatality distances since the sprites on home consoles are smaller. Then 1/2 screen isn't the same.
Very good. Btw it's mk1, mk2 and mk3 and umk3
