I got a U5000 chassis given to me in pieces with a new flyback soldered in, but the orange wire off of the flyback is not connected. Where does it go??
G2 pin on the neckboard. if it's a replacement flyback, it will not have the proper connector for hooking up to that pin. you will have to desolder that pin out, and solder the G2 wire in.
while you're checking connections, please verify your CRT ground is hooked up to the neckboard as well. what happened here?
Someone started working on this that did not know what they were doing. I was pretty sure it went to the pin on the neckboard, but was not able to look up the schematic. My buddy brought the thing to me in pieces and someone had already soldered in a replacement flyback, but the orange wire was soldered in the pin where the Horizontal sync is on the right side of the chassis. I was pretty damn sure it did not go there, but did not know exactly where it went!!
