I've got a U5000 with a weak tube. Can I use a standard TV tube with it, since it's dual res? I know on things like the 7500 you can't, as the dot pitch is finer.
The dot pitch of most standard TV's is actually quite a bit tighter than arcade monitors. Now, I don't know where a TV's pitch is going to fall in regards to standard/medium/high resolution.....but anything's better than a dark tube. Plus, the average person can't tell the difference.
