flip41126
Well I just got U5000 monitor back together. Original started with the thin line across the screen. Did the cap and the other 3 updates. Hooked it up, turned it on, nothing form the screen. The game did start. Could only adjust B+ @ TP202 to 119.2 volts min. This is running 25 kHz and should be at 117.2 volts. Also, checked TP203 and am only getting 1.72 volts. Turned off then back on. There was some wierd red flickering lines on the screen. Then blank. Then R760 got red hot and started to smoke. Opps.
