- Joined
- Jul 6, 2014
- Messages
- 315
- Reaction score
- 198
I recently decided to challenge myself with repairing the roughest chassis I had laying around the shop, and finally got it operational, I felt it was best to start a new thread for this question, you can find the original post on this here...
Anyway, after getting it operational I took a break until today when I tried to do some fine tuning and adjustment that's when I ran into an odd phenomenon, the top right quarter of the monitor started to completly cut in and out as the monitor warmed up (after about 10 minutes of operation). The rest of the monitor appears to be mostly unaffected by this. When I rebuilt the monitor I accidently replaced the original blown HOT with a used weaker 2SC3686 instead of the stronger 2SC3688, I had the 2SC3686 in the bag with the rest of my 2SC3688s and didn't realize until I started investigating this new issue. I'm not sure if a failing HOT can cause this issue or not, but I decided to replace the used 2SC3686 with a new 2SC3688 to see what would happen and it shorted immediately, which is odd since the 3686 is supposed to be weaker than the 3688. I replaced the flyback when I rebuilt this monitor due to the wire and anode cap having been terribly chewed on by rats. I've read that some new flybacks can blow some 2SC3688s should I try a FJL6920?
U5000 Adjusting H-hold and Width puts chassis into HV shutdown.
I have a U5000 chassis that has had a very bad time aside from recapping it had a dead or faulty... Q704 HOT Q101 MOSFET U101 PWM IC R104 R106 R117 R107 R100 R105 And as mentioned an missing L103 that someone replaced with a piece of stranded wire and a ferrite bead. After replacing...
forums.arcade-museum.com
