Well I have a Crusin USA, and I want to try to get the original U5000 working again(after it started popping fuses, I put a LCD in for temp just for party purposes, now thats all done. I want to get the original monitor working again). The Chassis says 738-F, looks to have the Vert Mod done too it already. I can't tell if the other two had been done though. It does need a cap kit. Which I will order.
The problem is this. It had been working just fine for quite a while. Then one day, it started to smell burnt and then it just pops the fuse. But not instantly, it will work for about a hour or more, then it will pop the fuse on the monitor again. So before it burnt anything else up, I decided to take it out of the cab till I could work on it.
What should I look/test for? I would like to order all the krap in one shot, as I hate to order a little at a time as all we have out here is a Radio Shack that doesn't carry squat anymore.
Now in my defense, I have used the "Search" button. But I mostly come up with "Won't turn on" or "Ticking" or links to the update kits. But I haven't found my particular problem. So any help would be great!! Thanks!
