U5000 Please help
bulldawg
North Carolina
I just picked up a game today that has a 25" wells u5000. The guy said it was working and when he moved it to his new place and plugged it in it did not work anymore. So when i got it home i plugged it up and the game works as i can hear it playing but the monitor only has a horizontal line across the middle of the screen. Any ideas?
u5000
Could be as simple as their is no cable pluged in for the external pot board, or the verticle yoke plug is off a pin or off completely. Ohm your v. yoke plug and see if you have about 5 to 13 ohms or so. Check your vert. output ic and see if there is a blown part in the middle of the ic. Then you have more problems if that happens.
I checked the pot board and thats not the problem. I will check the other tm. Thanks
