U5000 Convergence question
postmortem
Cape coral, Florida
I have an NFL Blitz with a U5000 that I recently capped. The corners of the screen look blurry. Someone told me to check the convergence and I can get the center of the monitor looking great. Just the corners arent as sharp. any ideas? thanks
there's those little magnetic strips that go between the yoke and the tube that take care of that. they're white, probably half inch thick if I remember right. if they're gone then that will probably cause it.
however, had a K7500 (similar to the U5000) where the corners were blurry and once I changed the flyback it got a little bit better. worth noting that tube was missing the wedges, and the tube was garbage anyway, so I swapped it with a different one.
