U2000/U5000/K7400 degaussing coil?
pun84
New Jersey
Do these chassis-es all use the same degaussing coil? I just did a tube swap on my U2000, but I forgot to save the degaussing coil... does anyone happen to know what kind of Resistance/Inductance the coil used for the U2000 chassis has?
I just fixed this u2000 and I don't wanna end up killing it!
thanks!
Just my .02, I've never heard of a degaussing coil being the wrong resistance or anything. They're all pretty similar, If it'll plug in you should be alright. I've never had any trouble out of one when I do a tube swap, I usually always use the ring from the new tube.
once in a great wile if i do a tube swap i will change the degauss coil on a tube.
otherwise i have always left the coil on the new tube and changed the connector.
never heard or seen any ill effects come from it.
Peace
buffett
