U2000 Neck Board
Radar
Brampton, Ontario, Canada
I have a P719 neck board with transister Q501 in place with a Cap from the base to a jumper wire. I had a problem with the monitor so I removed the Transister and cap. Montior works now but very dull. Why is this transister there when the schematic says it to be shorted. I could not find any reference to a mod. Should I replace the transister or leave it out.
Any help would be great.
If it was there and working right, then not there and not working right, I would put it back the way it was and see if that is the cause. WG has a history of doing undocumented modifications to chassis' if they need a little 'extra' to make them work properly in final testing....
Thanks for the reply. The monitor stop working so I removed the transister (As per schematic) to see it was the part causing the problem and it was. I will replace it to see if it wil bring back the color(Dull).
