U2000 chassis help
LittleTimmy
Wisconsin
Hey all,
Havin' a heck of time with one. It does not work at all, fuses are good. I did a cap kit, flyback, vert.sweep update and the power supply update. I have no neck glow and it is quiet, no snapping or noises like others have said. I have a dumb question... when people talk about adjusting the B+, is that checked at TP202B+, or TP203VID B+? or both?? It looks like someone was adjusting the pot because the glue is not on it. Also, dummy me was in desparation attempt to get this going, I turned it and resistor 728 was getting hot. I measured the resistor and it measures 1.063K ohms. I think it's suppose to be 1.0K ohms. This area always looked suspect to me because it looked like it was burnt(on board). I will probably replace that resistor, but any other ideas??I also checked:R811,R104,R310,D708,D104. I have a rejuvenator, and the tube itself checks out ok.Any help would be great. Thanks.
