TZ restore: Two problems left
JASaxman
Beckley, West Virginia
First off, I've never seen a restored TZ in person, and I must say WOW, it sure looks purty. Ok, enough of that, on to my problem.
After fixing over a hundred issues with this thing everything looks, and works perfectly, except two issues:
1. This problem has been with this machine since the start. When the Ball trough shoots a ball into the shooter lane, 2 out of 3 times it will bounce off the metal post, and back into the ball trough. I've tried everything from removing the post, to removing the rubber ring, and still the same result. If it doesn't bounce off the metal post, it will bounce off of the metal lane wall. Any idea's?
2. The out kicker in the Upper Lock at the top right of the playfield keeps kicking at random points. Two times each about every 2 minutes. There's nothing triggering the optos in the lock, and in the test menu, there is no errors. It does it in both Attract mode, and durring a game.
Any help would be appriciated, but to be honest, I'm just surprised at how well it shaped up. Took 2 weeks, but well worth it. Thanks again.
