Tz owners,free parts
pinman123
Louisiana
Hi guys, I have two Brand New universal WPC flipper boards and one used clock board that i would like to give to a KLOV member or members who could really use them for their machine.The universal boards can be used for type one or type two machines and they are adjustable for desired button press feel.I only used them for about 5 plays on my TZ.The clock is used and does have burn marks on it from the bulbs and the board does work but one of the optos on the hour side would sometimes register and sometimes it won't in the clock test it should be an easy fix.I only want to give these to a member who needs them and could use them and if you don't need the clock let another member have it who could fix it and use it for their TZ so once again please ONLY if you really need them and are going to use them.Thanks,Mike
Very cool of you!
Fortunately my TZ is in really good shape and only missing one small part. The post between the shooter lanes right above the small diverter. Just an empty hole there, can't find a part number in the manual either. Pinman, would you mind taking a look at yours and letting me know what I need to order, can't make it out properly from any photos I've seen.
Very cool of you!
Hi Kryzsky,I will look tonight when i get home and see and i will post,Mike
Very cool of you!
This is the post that goes between the shooter lanes.Let me know if you more help,MIKE
http://www.marcospecialties.com/product.asp?ic=02-4177
Thanks! I was pretty sure it was one of the pointy posts but had no idea on the height, wanted to make sure the correct parts are used.
I'm starting to think that post was removed on purpose. Watching the ball get kicked into the shooter lane leads me to believe it will hit that post everytime.
Yes alot of guys are removing that post because it is slightly in the way of the ball when being shot in that lane.
+1. One of every 10 balls shot out of there on my TZ hits that post but it usually just slows it down a little.
